Are These Problems Normal With New Cabinets? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 04:55 PM   #1
Rewards Points: 682
Are these problems normal with new cabinets?
Awhile back I installed some kitchen cabinets. Some of the the sides were not plumb and I had to belt sand them straight, otherwise I could not clamp and screw them together. Also not all the tops were level, sometimes the top of the front would be 1/16 " lower than the top of the side, and like that.
I was pressed for time so I did not consider taking them back to be replaced. Should I have done this? Or are these imperfections normal in new cabinets?
darsunt is offline   Reply With Quote
Old 05-31-2012, 05:22 PM   #2
Rewards Points: 268
They are only normal in low end mass produced cabinets. You should have returned them if possible. If not, you should have planed them down or used shims.
packer_rich is offline   Reply With Quote
The Following User Says Thank You to packer_rich For This Useful Post:
oh'mike (05-31-2012)
Old 05-31-2012, 06:08 PM   #3
Rewards Points: 682
Ah. A planer would have been better than a belt sander?
Old 05-31-2012, 08:49 PM   #4
Rewards Points: 268
yes.Faster and flatter.
Old 05-31-2012, 09:02 PM   #5
Rewards Points: 13,260
I just use a set of these. There going to be able to pull them together and hold the faces flat at the same time.
New Cabinets sweaty General DIY Discussions 9 09-14-2011 07:09 PM
install kit base cabinets - floor not level eastside Carpentry 10 05-07-2011 11:09 PM
Framework to space cabinets from wall red3908v Building & Construction 6 08-02-2008 05:45 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 08:48 PM
