Is There A Way To Prevent A Marcraft Vanity Top From Scratching So Easily? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 10:07 PM   #1
Is there a way to prevent a Marcraft vanity top from scratching so easily?
I recently purchased a Marcraft cultured marble vanity top, and today while installing it, I noticed it scraches very easily. I think my primary mistake was ordering the vanity top with a gloss finish.
Is there any way to prevent the vanity top from scratching so easily?
The cultured marble is made from crushed marble and polyester resin, in case that helps.
Swazzle is offline   Reply With Quote
Old 07-22-2010, 05:36 AM   #2
the Musigician
DangerMouse's Avatar
Lay a " beveled glass sheet over it or do not put anything 'scratchy' on it?
DM
Old 07-22-2010, 03:24 PM   #3
Rewards Points: 5,336
These tops have a relatively short lifespan. They usually rupture around the drain within 5 years.
Unless you're good at stone refinishing, you're stuck with this situation.
As Danger said, keep items harder then the finish off the surface.
Ron
Vanity - too tight a fit? 9728 Building & Construction 7 12-14-2009 08:42 AM
HELP! Vanity tight squeeze 9728 Kitchen & Bath Remodeling 1 12-11-2009 02:53 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
Vanity Tight Fit Chemist1961 Remodeling 2 01-10-2009 02:30 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
