Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-27-2010, 08:58 PM   #1
Is there an easy section to cut out one piece of a baseboard?
I have about a 1' section that warped due to water, on a 15' wall, is there an easy way to cut out just that one section and replace it? Or should I just take that whole piece off?
abefroman is offline   Reply With Quote
Old 07-27-2010, 10:12 PM   #2
Super Moderator
You will need to pull the whole piece off---only way I know to make it look right.---Mike--
oh'mike is online now   Reply With Quote
Old 07-28-2010, 03:00 PM   #3
You CAN remove a section and patch, but the effort involved might make it work replacing the entire length.
First off, given that it is a 15' span, chances are it is two pieces scarffed together.
If you chose to try to replace, tools and supplies to consider are a multi-cutting tool - something similar to http://www.harborfreight.com/multifu...ool-67256.html. Cut out the offending piece, cut a piece to fit and use drywall mud to fill. I have found this to be an extremely effective method of filling painted moldings. Really good on crown. Pick up some 20 minute mud at the local store, mix and apply. Wait the 20 minutes, sand the finish, primer (VERY important) and paint. Should look seamless.
unlvrebel is offline   Reply With Quote
Baseboard heater under window jhubert Electrical 1 10-07-2009 11:59 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Caulk underneath sink drain/plate? doogie88 Plumbing 14 04-16-2009 08:18 AM
Baseboard trim height from floor billyg Carpentry 6 01-20-2009 11:08 PM
Replaceing Baseboard to curvy wall problem agfrag Carpentry 13 08-29-2008 04:40 PM
