#1 |
Temporary walls
I want to remove a non load bearing wall in my kitchen and replace it with LVL engineered beams. It is attic space above with paper backed insulation 8 inches thick, drywall with stucko. When I build the temporary support walls can I increase the spacing of the studs from 16 inch to 24 or perhaps 30 inch centers? It will just make access between the walls so much easier. I plan on using 3- 1 1/2 x 12" x 20' beams on steel posts in place of the existing wall
#2 |
Mod
Temporary walls
I vote yes, even if there was any slight temporary sagging due to your 30” centers your new beam would straighten it all out.
The ceiling won’t collapse.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#3 |
Moderator
Temporary walls
Why a temp wall if truly non-bearing? Why a LVL, not another couple of ceiling joists (2x12) with spacer between? You are holding up drywall (1/2 of the span from wall to next joist) and texture, on both sides.
Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#4 | |
Mod
Temporary wallsQuote:
. If they do, a temp. all wouldn’t hurt but wouldn't necessarily be necessary either. Not much different than do I need to jack my house up to replace a few feet of rotted sill.
#5 |
Temporary walls
I do not want a bulk head (this is going to open up the kitchen/ living room)so to get a flat ceiling I will be cutting out a piece of the ceiling joists (4.5 in )to insert the beams with steel posts and use hangers. That is why I need temporary walls. LVL is to be used because the span of 20 feet is exactly what they are designed for, they have no crown and when bolted and glued together they will not sag or shrink with age. I will be installing the posts over a 6 inch I beam that runs the length of the basement.
#6 |
Moderator
Temporary walls
So the ceiling joists are bearing on the new beam.... Part of the roof framing may be supported as well if you have any purlins and struts in the attic: Page #39: http://books.google.com/books?id=iwS...joists&f=false
The ceiling joists are under tension holding the exterior walls together, keeping the rafters up off your head when eating breakfast. (Page #40). If you hanger them, use a LUS (shear) hanger and the proper size nail called for or take a reduction for the uplift loads and shear flow (not advisable). http://myconco.com/ComEngProb.html All shear hangers require the longer nails: http://www.strongtie.com/products/co...ace_ss-df1.asp Remember to add floor space solid blocking if the posts don’t rest directly on the beam below. Use a temporary wall depending on the drywall ceiling finish (texture mud, stucco, etc.), the joist span, and the insulation load. NOTE: you had a distributed load and are changing to concentrated loads. I suggest consulting a Structural Engineer and going through your local building Department. Be safe, Gary
| Display Modes | |
| Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? | xray328 | Remodeling | 27 | 06-19-2011 09:50 PM |
| Insulating walls for heated garage | Huskie | Building & Construction | 5 | 09-19-2009 01:54 PM |
| Installing Plumbing in 2” Wide Walls? | Robert1_1 | Plumbing | 5 | 09-16-2009 09:43 AM |
| bowing walls - repair? | elementx440 | Building & Construction | 26 | 03-04-2009 04:07 PM |
| Moisture on walls | chrisr | Building & Construction | 1 | 01-20-2008 10:37 AM |
