Temporary Suport In Old House - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 09:26 PM   #1
Rewards Points: 150
Temporary suport in old house
My house was built in 1863 so it has balloon framing. I will be taking out two large windows so I can remodel a bathroom. I will be putting in a smaller window. I have not taken out the plaster to see what I have there yet. I would like to know now about any temporary support of balloon framing and any other concerns I have not considered. If I am just putting in a new window in one day do I have to worry about temporary support?
Cossack is offline   Reply With Quote
Old 03-31-2010, 11:04 PM   #2
Remodeling Contractor
depends on the wall you are putting this window in Balloon framing goes all the way up and may support the roof. So support is needed. nail a 2X6 over the opening and brace posts at an angle from the floor to support it while you cut and install the headers.
Old 04-01-2010, 05:40 PM   #3
Rewards Points: 150
I thought about this after I posted. I am putting in a smaller window so the headers and such should already be there. The old larger windows should not be holding anything up so don't I just have to build in a smaller frame?
Old 04-01-2010, 06:26 PM   #4
yes, if this is only replacement with a smaller window, then no support needed, just new studs to support the window. double studs would be better with the opening level and 1" bigger then the window. then fill area with non-expanding (blue can) spray foam.
Old 04-04-2010, 09:16 PM   #5
Heritage Restoration
Is the window that you're taking out an original to the house?
If it is....there are a few people I know that would probably be happy to take it off your hands. What state are you in?
Skuce is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 12:43 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 01:41 PM
