Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-26-2007, 04:16 PM   #1
temporary basement jacks
when rebuilding exterior garage wall[see prev. post], we will need at least 3 temp. basement jacks. we have found ellis jacks online that use either 4x4s or 6x6 posts w/ their screw jacks. we live in texas and basements arent plentiful, and we are having a hard time finding a rental place that rents jacks of the steel pole type that i have seen used up north. any help locating these would be very helpful...dharp
dharp is offline   Reply With Quote
Old 11-26-2007, 05:38 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Why don't you look into house jacks instead of those pole jacks?
http://f5c.yahoofs.com/shopping/mcid..._____DFzjIWhdr
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-26-2007, 05:56 PM   #3
ICF Construction
If you want/need pole jacks, check with a local ICF contractor/distributor that installs/sells Lite-Deck or Insuldeck, the shoring jacks they use are perfect for what you need. I am surprised you local rental company does not have them available.
Chris
Chris Johnson is offline   Reply With Quote
Old 11-27-2007, 08:22 AM   #4
thanx chris, we live in a small resort town in texas, ive been checking in the dallas/ft worth area, the truth is nobody builds basements down here, which might explain the problem
Old 11-28-2007, 08:39 PM   #5
Woodworker and Contractor
Kingfisher's Avatar
Use a car jack with a 4x4. Have a 4x4 ready and place in beside the one you are using too jack up the load with, raise it about 1/8 then wedge the other 4x4 in place, lower the jack and repeat. Make sure you use a good base plate if it a dirt floor. You can also just pound the wedges in with a small sledge and raise the load that way too and skip the jack measure every place first so you know if you are lifting.
Kingfisher is offline   Reply With Quote
Old 11-28-2007, 10:39 PM   #6
Go to your local Sears, they sell 20 ton jacks you can use with a 4x4 or 6x6.
Ron
Old 11-29-2007, 12:51 PM   #7
Kingfisher's Avatar
The car jack was suppose to be a bottle jack sorry. You should not need over a 6 ton for any one point. Do not leave the load on the jack alone in case it leaks, always barce it off like I described safety, safety, safety
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Can floor jacks in basement be permanent? ragtopdave06 Remodeling 15 03-15-2007 06:23 PM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
