Tar Paper On Ceiling/floor Water Damaged It Is It Needed? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 06:06 PM   #1
Rewards Points: 89
tar paper on ceiling/floor water damaged it is it needed?
cut out part of the ceiling on main floor from water damage.
there is a heavy paper covering the flooring to the second level and it is torn and hanging back.
Is this needed? can it be taped back up or does it need replaced there? If needs replaced can tyvec work? I have some left from siding the house.
papason is offline   Reply With Quote
Old 05-20-2012, 06:40 PM   #2
DIY staff
Rewards Points: 7,174
That is an old vapor barrier--good to have years ago when people seldom heated the second floor---
Not needed today ,if your second floor is heated--
Just staple it back and forget about it---
gregzoll (05-20-2012)
Old 05-20-2012, 07:49 PM   #3
Rewards Points: 89
Thank you.
I could not understand why a vapor barrier , so I was not sure of what was . I will staple it back, thanks again.
It was heated when built tho
The Following User Says Thank You to papason For This Useful Post:
oh'mike (05-21-2012)
Old 05-21-2012, 08:48 PM   #4
Registered User
Rewards Points: 5,244
I'd put it back, also. Especially if there is wood strip flooring above a bathroom, kitchen or laundry room, places of high moisture that could warp the wood flooring, mainly air-leaks around the ceiling light fixture, less= diffusion through the drywall/plaster. Mike's is the primary answer, though, just thinking if it was a newer house- or an older one and someone thought ahead.
Gary
Removing old damaged insulation Megsmom88 Insulation 9 04-11-2012 08:52 PM
Peeled off Sheetrock Paper - HELP!! HomeHell Painting 8 02-21-2012 06:14 PM
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 10:59 AM
new tar paper with to tie in with existing roof tar paper. accordfreak Roofing/Siding 1 06-24-2011 08:58 AM
Painting over damaged drywall... tmsurf8 Painting 4 08-19-2010 05:07 PM
