Tapcon Into Concrete. - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-22-2008, 03:04 PM   #1
Tapcon into concrete.
I am applying extruded foam to my concrete walls and I see a lot of references to hammer drills. What is the difference between a hammer drill and a normal drill?
smorgdonkey is offline   Reply With Quote
Old 09-22-2008, 03:10 PM   #2
47_47's Avatar
Rewards Points: 58
A regular drill just spins, while a hammer drill spins and hammers the bit. Concrete is a mixture of cement, sand and aggregate (stones). A regular drill will hit a stone and go no further. The hammering action will split the small stones and drill through them.
47_47 is offline   Reply With Quote
Old 09-22-2008, 03:27 PM   #3
Thank you for that. I am currently using a normal drill...so now I know that if I run into something that I might just 'in and out' the drill a little...not that it is the best solution but it might do the trick!
Thanks again.
Old 09-22-2008, 06:49 PM   #4
Registered User
Termite's Avatar
It won't.
A hammer drill hammers thousands of times a minute. You can't replicate that.
Old 09-22-2008, 06:58 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
the termite is correct! it reminds me seeing a home owner using a sawzall as a hand saw unplugged. why bother.
Old 09-22-2008, 07:53 PM   #6
Originally Posted by thekctermite View Post
It won't.
...but...but...I'm a machine!!
Old 09-23-2008, 06:31 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
You also need to use carbide tipped masonry drills in your drill for making holes in concrete, hammer or otherwise. If you are installing Tapcons as the title says, you also need to be sure they are the correct diameter for your Tapcons, otherwise you will either break the Tapcons or they will pull out.
Old 09-23-2008, 06:59 AM   #8
Yes. Great point. I am using the bit that comes in the box with the Tapcons.
Old 09-23-2008, 07:41 AM   #9
RippySkippy's Avatar
Also, use a nut driver in the hammer drill to install the tapcons with the hammering action engaged. Those that would twist off with a normal drill will sink like they were going into butta!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 09-23-2008, 10:35 AM   #10
Registered User
Termite's Avatar
He's kinda lacking the hammer feature.
Old 09-23-2008, 10:52 AM   #11
47_47's Avatar
Rewards Points: 58
As the op states
Old 09-23-2008, 11:25 AM   #12
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,360
I spent 2 hours trying to drill a hole in concrete with a regular drill with a masonary drill bit. I still didn't get it deep enough to be any good. A hammer drill did the job in about 30 seconds.
A regular drill drills by cutting, a hammer drill drills by chiseling.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 09-23-2008, 01:38 PM   #13
O P if you dont mind me asking, exactly what is your project and what type of foam are you using?
baxter is offline   Reply With Quote
Old 09-23-2008, 08:01 PM   #14
What can I find here?
Winchester's Avatar
Rewards Points: 150
Why not a proper construction adhesive?
A hammer drill is like a jackhammer vs. using shear pressure to break up concrete pads.
Winchester is offline   Reply With Quote
Old 09-23-2008, 11:43 PM   #15
Rewards Points: 2,906
Another way to attach foam to concrete is to use "stick clips".
A stick clip has a large base that you glue to the concrete. Out of the middle of the base is a prong that's 2, 3, 4, 6 or 8 inches long.
You just impale the foam onto the sticks, and then push on metal "washers" (that will push on, but won't come off) to hold the foam snugly in place.
You can buy stick clips at any hardware store or home center.
Nestor_Kelebay is offline   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
