Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-01-2009, 09:42 PM   #1
sdj
t bar ceiling
Hello,
I have purchased 2 x 2 recessed ceiling tiles and I am looking for the best way to cut them to size. I also have to cut the recess in and would like any suggestions.
sdj is offline   Reply With Quote
Old 03-02-2009, 06:31 AM   #2
Remodeling Contractor
t bar ceiling
If you are talking about making the 3/8" recess at the edge for the dropped tile effect, buy the tool that is made for this. It will save tons of work. Some here have complained that it was too hard to make these cuts, but that is what happens when you do not use the correct tool for the job. It's cheap!
Old 03-02-2009, 06:42 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
t bar ceiling
check this out http://www.bontool.com/product1.asp?...roductlistings Its cheep! About $2.00
Old 03-02-2009, 02:37 PM   #4
Drywall contractor
t bar ceiling
The best way is to "freehand" it if you want your cuts to compensate for irregularities in the wall. Measure from inside edge of your cross tee to the edge of the wall angle. Best to measure both sides and go with the longer of the two if your wall is out a bit. Measure from the "reveal" lip on the tile and add 1/4" to get your overall length. (If you measured 16-3/4" from grid to grid, cut the tile 17".) Lay your tile in the opening, tight to the cross tee. Take your razor knife and lightly run it along the edge of the wall angle to "scribe" the exact line you need to cut (I usually do it twice). Take the tile out, cut the line again with enough pressure to cut about 1/2 way through, then cut from the edge into your scribe line to remove the reveal. Keep your blade sharp (yes you can sharpen a utility knife blade) or replace often. Ceiling tile usually dulls a blade pretty quickly (some brands faster than others) and a good job requires a clean cut. I've even seen the "reveal cutters" at HD, but you can't compensate for an out of square ceiling or a bow in a wall unless you use the method I discribed.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-03-2009, 09:13 AM   #5
t bar ceiling
bjbatlanta has the right idea. I did acoustical ceilings for about 3 years in commercial jobs like hospitals and the green bay packers stadium and I will tell you that you will get much better results free handing the cuts then using the tool. The only difference I did then bjb was I measured from the inside of the wall angle(lay the tape measure on top of the wall angle and butt against the wall) and measure to the edge of the tee. Walls are not perfectly straight and that tool will never give a reveal that follows the wall angle exactly. If you do as bjb suggested your tile lip will follow the wall angle perfectly.
ponch37300 is offline   Reply With Quote
Old 03-03-2009, 10:29 AM   #6
Drywall contractor
t bar ceiling
I measure regular lay-in tile the way Ponch described. With the reveal, the narrower the lip you have to cut, the easier it seems to be. Measuring wall to grid leaves a slightly wider edge. Either way works fine.
Old 03-04-2009, 07:20 PM   #7
sdj
t bar ceiling
Thanks for the replies. You have given me some good ideas
Old 03-04-2009, 07:21 PM   #8
sdj
t bar ceiling
And i do suport our troops god bless
Old 03-04-2009, 08:51 PM   #9
Drywall contractor
t bar ceiling
Thank you (and all) for your support, sjd. Hope the ceiling turns out well!
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
