Supporting A Cantilevered Header - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-29-2007, 12:38 PM   #1
Supporting a cantilevered header
I am doing a small remodel to open up a wall between my kichen and living room, and OOPS!!! there is a header (4x8) that is cantilevered out over where my countertop will extend. Currently, the framing supports UNDER the beam, but I want to move the support over about 4 inches, and was wondering if it would be structurally equivelant to use a beam-to-post type bracket and a post instead?
Thanks for the help,
Brandon.
blschmitz is offline   Reply With Quote
Old 11-29-2007, 12:48 PM   #2
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
yes, just make sure its sized for the load, not just the first thing you find
Kingfisher is offline   Reply With Quote
Old 11-29-2007, 01:00 PM   #3
The bracket, or the post? Or both probably, huh. Thanks for the quick advice. I have no idea how to figure out the load on the header, but the existing framing that supports it is 2 2x4's at a 90 degree agle to one another. I would imagine that a 4x4 post would be at least as strong, would you agree?
Old 11-29-2007, 01:27 PM   #4
Kingfisher's Avatar
Rewards Points: 150
Yes, but is any of this going to show or are you going to wrap it with something. Not all woods hold the same loads and you'll have a hard time find a 4x4 in anything but PT or cedar aroung here. I would not use cedar for that.
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
Surprise - no header Clutchcargo Building & Construction 4 09-08-2007 07:17 PM
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 06:11 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
