Sunroom Or Regular Room? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-14-2007, 12:23 PM   #1
Sunroom or Regular Room?
What are the advantages of adding a sunroom instead of a regular room addition?
cardiff is offline   Reply With Quote
Old 11-14-2007, 06:26 PM   #2
Sunrooms may be installed on a variety of approved foundations (deck, concrete) in just one to five days, compared to the weeks or months required for a standard room addition.
By code, a sunroom may be designed with a large glass area (65% or more) that is not possible in conventional room additions. Its design does not include a permanent heating or cooling system and in the northern climates you must have a door separating it from your living space which is a disadvantage from a conventional room addition. If your looking for a heated 4 season room then a Sunroom is out of the question. I have installed many Sunrooms and I personally would rather a standard room addition.
Hartford is offline   Reply With Quote
Old 11-15-2007, 11:30 AM   #3
Sun rooms may provide you a chance to sit in the outdoors, no matter what season it is, however you have to make sure that it's well insulated and accessible for use during all seasons.
Kitchen sinks is offline   Reply With Quote
Old 11-15-2007, 12:23 PM   #4
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
I added a screened room to my home that I will eventually turn into a sunroom.This will provide me with the opportunity to basically be outdoors without the mosquitoes zeroing in on my family.since it is nothing but a covered,non heated living space ,the assessment is less for tax purposes.It's large enough for having company,(12x24)and can easily be used for an overnight guest,weather permitting.
It's a place to operate my grill in the winter,or rainy days.A good place for a hammock,watching over the kids in the pool while staying out of the sun,storing firewood out of the weather.
Some of these things I won't be able to do once it's a sunroom,unless I make the glass removable,but,my point is,what do you expect to gain from this addition?What's your lifestyle,and do you want four season use from it.
Sunrooms can heat up quickly and become unbearably hot,limiting their usage.If you install some sort of shading,then you lose the advantage of the windows.
Decide your expected use,then go for the components which will make the most enjoyable for you.
oldfrt is offline   Reply With Quote
Old 11-18-2007, 01:46 PM   #5
The cost would be somewhat less for the sun room. However, the resale value will be much less. Also, as mentioned, your climate will be the biggest point to consider. If it can be used four seasons, go for it, IMHO.
Handyman50 is offline   Reply With Quote
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 10:35 AM
My kids room is cold snmhanson HVAC 5 12-20-2006 11:51 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
Load calcs for room addition Jim Tyson HVAC 1 02-23-2006 05:36 PM
