Sump Pump Drain System Installations - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 02:20 PM   #1
sump pump drain system installations
I recently had a system installed and I'm about to drywall, which means I have to frame first with studs. The drain installer told me that I would have to glue my footer board to the concrete because I would ruin the integrity of the drain system if I nailed through the concrete... Has anyone heard of gluing your footers without nailing them? Is this common?
WAINSWURLD is offline   Reply With Quote
Old 02-15-2012, 10:14 PM   #2
Rewards Points: 150
last I heard, water doesn't flow up. I don't see how it'd be an issue.
alecmcmahon is offline   Reply With Quote
Old 02-16-2012, 10:52 AM   #3
Rewards Points: 150
Are the tiles that run to the sump that shallow?
psilva8 is offline   Reply With Quote
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 02:17 PM
understanding the numbers on a sump pump and which one to buy ksimpson Plumbing 0 09-09-2011 08:51 AM
Sump pump...how does it work?...pics MecGen Plumbing 6 06-18-2011 08:28 AM
Dry sump pump pit/failing septic system Jenn M. Plumbing 4 01-08-2010 10:01 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
