Suggestion On Adding Insulation - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 07:09 PM   #1
suggestion on adding insulation
currently redoing my basement - block wall about 3ft tall (just above grade) with studded wall with craft faced isulation ontop of that. Will be reframing new walls slightly away from the block wall. I have read that you should place craft faced over craft faced insulation as it could collect moisture. In order to save time and money, would like to leave the existing insulation in place. If I were to cut slits up and down, would that be enough to allow moisture past through. Or should I just bite the bullet and replace with unfaced?
thanks.
js2318 is offline   Reply With Quote
Old 01-10-2009, 08:12 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
Slash the kraft face to destroy any sort of vapor barrier/vapor retardant properties it mght have.
You cannot allow any moisture/vapor to get into fiberglass since it never dries out, holds moisture and can add to mold growth.
concretemasonry is offline   Reply With Quote
Adding insulation to a low-slope roof cbeingessner Roofing/Siding 25 09-21-2010 11:01 AM
Adding insulation? kcrossley2 Building & Construction 2 12-03-2008 07:43 PM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
Adding Insulation with Re-roof Finigan Roofing/Siding 2 03-02-2008 10:25 PM
adding to existing insulation renegade Building & Construction 2 01-23-2008 10:46 PM
