Subfloor Vs Underlayment - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-18-2007, 03:34 PM   #1
Subfloor vs Underlayment
Hi All,
We're putting down cork flooring in our kitchen and there's currently three layers of vinyl there. I've started to attempt to remove it but it's a pain in the ass. Under the vinyl there's 1/2" plywood and then under that it looks like tongue in groove slats. Are the slats the subfloor and the plywood the underlayment. Can I just take my circular saw to the underlayment (if that's what it is) and replace the plywood? Any tips and tricks if I choose to go this route?
Thanks!
indignatz is offline   Reply With Quote
Old 11-18-2007, 08:57 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Yes, the T&G is the subflooring and the plywood is the underlayment.
You can remove the underlayment along with everything on top of it by sawing and prying it out in small sections.
You will need a circular saw with an old blade (you WILL hit nails), gloves, safety glasses, crowbar, pry bar, hammer, etc. to remove it. Adjust the saw blade to the depth of the plywood only, so that you don't damage the subfloor.
I usually don't cut more than a 2-foot or less section out at a time.
Stagger the sheets of the new flooring, and glue and screw them down. If this floor is over an unheated basement or crawlspace, you need to put a vapor barrier of roofing felt down on top of the subfloor, overlapping the edges a few inches.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-19-2007, 11:38 AM   #3
Thanks Mike. One question for you, what is the reason for gluing down the underlayment? Wouldn't that make it much more difficult to remove if I ever had to replace it again in the future?
Old 12-01-2007, 09:20 AM   #4
New
1/4 inch underlayment OSB or plywood
Have 1/2 inch subfloor. Plan to install 3/4 solid wood floor. Instructions call for 3/4 inch subfloor. Can I use 1/4 OSB as underlayment? With only 1/4 inch for screws does it matter OSB or plywood?
New is offline   Reply With Quote
Old 12-01-2007, 11:16 AM   #5
Long-Time DIYer
The purpose of using Liquid Nails or other construction adhesive is to prevent sqeaking of the flooring on nails. Almost all flooring will "give and buckle" a bit with swelling and shrinking of the wood.
It may make a little more difficult to remove later, but it is worth it for all of the years that it will be in place.
Mike
Old 12-01-2007, 11:18 AM   #6
Long-Time DIYer
new,
You can use OSB or plywood for underlayment, but if it were me, I would go with plywood. You will be screwing or nailing right through both layers of the subflooring, and plywood holds better than OSB IMHO.
Mike
Old 12-01-2007, 02:19 PM   #7
Home Improvement Guy
ron schenker's Avatar
I would put those screws into the joists about every 6"
ron schenker is offline   Reply With Quote
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
underlayment for laminate in Indy/Crawl Foundation? kenn Flooring 1 07-25-2005 11:42 AM
Underlayment for laminate dm62 Flooring 3 04-02-2005 10:56 AM
