Subfloor Advice - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 09:22 PM   #1
subfloor advice
I am looking to start my basement remodel and the first of many questions i have is that i am planning on using the delta-fl membrane then plywood for a sub floor. Would anyone recommend laying the subfloor first then the walls or walls first then floor and any advantages or experiences of both ways. Thanks
njdiy is offline   Reply With Quote
Old 05-10-2013, 08:17 AM   #2
Rewards Points: 3,130
I'd put the walls up first. Never seen it done any other way. Be sure the bottom plates are pressure treated.
Rather than plywood, I would use Advantec subflooring. It has a 50-year water damage warranty.
Old 05-10-2013, 03:42 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
if your building a subfloor instead of using a floating subfloor. build the subfloor first then build your walls. by doing this youll have a much easier time fastening your bottom plates down
woodworkbykirk is offline   Reply With Quote
Old 05-10-2013, 11:22 PM   #4
Rewards Points: 512
is the delta membrane rated for using a subfloor? from what i recall the plastic is pretty thin.i've always used platon. then tongue and groove plywood on top. and i would build your walls first with pressure treated plates then your subfloor. just think if you had a water problem and you had to pull that subfloor up and your walls were sitting on it.
princelake is offline   Reply With Quote
