studs on basement walls
You shouldn't ever put wood right up against concrete walls. Codes are different everywhere (countries, states, counties, etc). Update your profile and add your location!
How are you insulating the walls?
Are you using furring strips or regular 2x4 construction?
If 2x4, why not come off the wall an inch or so? Make sure your wall is straight too. This means you may have to come off the wall several inches in places if the wall bulges in certain areas.
I know on my wall I came off about 3-4 inches.
Basement Demo started Jan 2012: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Bathroom demo started Feb 2013: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
