Stud Blocking Behind Cabinets?? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-18-2009, 10:44 AM   #1
Stud Blocking behind cabinets??
Ok, so this will probably sound like a dumb question..
But I'm thinking about putting in blocking pieces behind new cabinets that are coming so that I won't have to worry about whether or not the studs will be in the right place to hang them...
If I put in 2x4 blocking, do they need to be put in with the 1 1/2" side facing out? Or will they support the weight if I put them in with the wide side facing out? I was thinking that, the bigger surface area --the easier for me..
dirtmcgirt79 is offline   Reply With Quote
Old 06-18-2009, 10:49 AM   #2
joed's Avatar
Rewards Points: 12,016
You can put them in with the wide side facing out. Also consider using something larger than a 2x4. Go 2x8 or even 2x12.
Old 06-18-2009, 11:46 AM   #3
Rewards Points: 5,336
If you plan out the cabinet installation, using 2x6 on the flat will give you more then an adequate support surface. I install them on both the top and bottom of the projected cabinet placement.
Ron
Old 06-18-2009, 01:14 PM   #4
Sounds good.. Another question is though.. Did you have to toenail the pieces in? Otherwise, how would you get the screws in the sides with the last one you installed in the way?
Old 06-18-2009, 02:22 PM   #5
You screw in the face of the board so it's below the surface. You can also toe nail the board on the narrow edge.
Ron
Old 06-18-2009, 07:13 PM   #6
joed's Avatar
Toe nail one end and through the stud the end when possible.
Old 06-18-2009, 07:25 PM   #7
I have also seen people notch the studs 3/4" & put a piece of 3/4" along the wall. And other people have attached a 3/4" piece directly to the studs, then filled in with sheetrock. The people that did this were tiling below the cabinets which covered the 1/4"
They also had open shelving at each end that covered the 1/4" there - or the cabinets ran into a corner
Or you can use 5/8" sheetrock to bring the gap down to 1/8"
I have existing studs in the kitchen & will be tiling
So I will probably put up the 3/4" board along the wall & fill in with sheetrock around them. I'll know better when I open the walls
Old 06-18-2009, 09:06 PM   #8
Registered User
Rewards Points: 5,236
If exposed, backing behind the microwave over the range, at sides of window or glass door for curtains, at the doorstop for a door-down low, behind the pot filler, behind the overhead florescent light fixture at ceiling, centered in ceiling over pendant lights, behind the stove plug (ask electrician,any pan boxes, the good ones do their own), side of door to move light switch over for casing, and next to each side of door and window stud/trimmer for using wide casing. Be safe, G
Is it safe to remove this stud? lofar Remodeling 4 06-17-2009 12:22 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
installing wood blocking sonnycrockett General DIY Discussions 8 06-15-2008 06:39 PM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 11:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
