Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-07-2012, 03:34 PM   #1
Stucco over asbestos siding - Expensive Process?
Has anyone every had a house with asbestos siding covered by having it stuccoed over the asbestos siding? Is it expensive to do this?
Maria76 is offline   Reply With Quote
Old 10-08-2012, 07:22 PM   #2
What type of siding are you considering asbestos siding? and what do you mean by stucco? masonry stucco or an Exterior Insulating Finishing System (EIFS). Anytime you are installing a new siding over an existing siding material the existing siding material must be sound. I always remove the existing siding before installing the new. It just makes for a better job, e.g. doesn't bury the window trim and, when appropriate, allows for a house wrap to reduce air infiltration. It would benefit you to post a photo of the existing.
TheCamper is offline   Reply With Quote
Old 10-08-2012, 09:30 PM   #3
Thank you'd or your reply. Dont have a photo to post right now. House is not mine yet. Just asking the best way to replace the asbestos siding if I do buy the house.
Tags
asbestos siding, covering asbestos, stucco
Botched asbestos removal in home... runfrombears General Discussion 28 07-31-2012 10:21 PM
Remove asbestos siding or cover Branden Building & Construction 3 05-18-2010 11:06 AM
Seamless Steel Siding & Stucco MySam Building & Construction 5 09-11-2009 03:43 PM
Siding vs. Stucco? jkrodger Building & Construction 3 03-06-2009 03:31 PM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 11:35 PM
