Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-26-2009, 04:07 PM   #1
Default Strengthening stairs with less support
I have an in-law apt that I currently rent out and want to add a washer and dryer to the unit. Plumbing and wiring are not an issue with the kitchen next to this space and a crawl space for wires. However, space is limited and adding onto this addition is not possible at this time.
Currently the apt can be accessed by its own front door or through a separate entrance through the garage. (You can see the stairs leading from the garage down into the unit in the far right of the first picture.) If I remove those stairs I can tap into the water and waste lines I would need. I would then need to block in the door. This would provide plenty of space but effectively make the only way into this unit from the outside front door.
My second option would leave those stairs in place but move the washer and dryer units in the space under the upstairs (Pic 3). I am wondering if I could remove the wall (and supports) to the stairs heading to the second floor without compromising the structural integrity. The stairs were constructed with 2 stringers and the support half way up the stairs. 8 stairs make up the total risers after the 3 stair landing on the left. If I add another stringer in the middle would this offer enough support without having to drop a support down to the floor? Would I want to double up the sides as well? The stairs are solid right now and I don’t want to change anything that will make them have give.
strengthening-stairs-less-support-stair1.jpg   strengthening-stairs-less-support-stair2.jpg   strengthening-stairs-less-support-stair3.jpg
HitLines is offline   Reply With Quote
Old 10-30-2009, 01:45 AM   #2
There doesn't appear to be enough room in front of the stairs (landing of 36" required): http://www.codecheck.com/cc/pg07_08building.html http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Tags
stairs, stringer, support
More On This Topic
We're going to try first, to pull their existing duct work. I've checked with all the mechanicals, it looks like this air conditioning system can carry the load, of this extra square footage. We're going to try that first, if we need to then supplement... Read More »
Hi I'm Drew Finn here for expertvillage.com we are going to show you how to install garage door opener today this is being filmed by Black Dog Video you could visit us at blackdogvideo.biz. Now we are going to mount the drive head to the ceiling. First... Read More »
The presence of mold in the home can potentially have very dangerous consequences to your health, the health of your family and that of your pets. It is important that you locate dangerous mold in your home, remove it and dispose of it properly in order... Read More »
Hi, my name is Leslie Moselle. I'm from Tampa, Florida and on behalf of Expert Village this is how to do laundry. First thing you want to do when doing your laundry is to first familiarized yourself with the settings of your washer and dryer. All washers... Read More »
In painting my walls, I’ve come across an issue that I need to deal with, and that is this 220 volt outlet. We used to have the washing machine and the dryer upstairs and we’ve moved it to the basement. This can’t come out, and we... Read More »
Help with staining my stairs kimber Flooring 0 10-22-2009 02:49 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 01:50 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 09:03 PM
Outdoor stairs need to be fixed... 2031pratt Carpentry 2 08-06-2009 01:06 AM
Questions about building stairs. cvriv.charles Building & Construction 5 07-05-2009 04:50 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
