Stream In Basement - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-05-2008, 05:29 PM   #1
Stream in basement
I have an unfinished basement. Since I bought the house, we have always had water in the basement when it rains. I added gutters to the entire house. That didnt' help. Most of my house has a stone foundation with a concrete floor. I would like to divert the water away from the walking surfaces of the floor, and keep it close to the walls. I found a product, SquidGee System, that I think would work to divert the water around the walls and into the sump pump. However, this system is way too expensive. does anyone know of a similar system that is not so ridiculus? That is $12 for a 4' piece just for the main section.
I also thought I could get some cheap vinyl "U" shaped gutters. Then rip them down the center on my table saw. Then I would have two "L" shaped sections to glue to the floor. Any thoughts?
If I did it this way, what would be the best thing to glue this vinyl gutters to the concrete floor?
Any help would be greatly appreciated.
Here is a link to the SquidGee System I was talking about: http://www.waterproof.com/wetbasement.html
rizaydog is offline   Reply With Quote
Old 02-06-2008, 02:08 PM   #2
Rewards Points: 150
MOST water problems come from two sources,,,
#1 would be outside grade around the house, letting water filter into basement by channeling from puddles. Does your outside grade slope at least 6" in first 2 foot and then 6" in next 4' AWAY from your foundation with NO puddles when it rains within 25 -35 feet of the house??
#2the natural ground water level is higher than the floor, specially under rainy conditions!! If so,,, NO solutions for this other than a full drain tile install and a pit with a sump pump.(and thats not 100% cure either)
Both of the above cures 75-90 % of all water probs.
justdon is offline   Reply With Quote
Basement leak dougrus Building & Construction 7 12-31-2007 07:06 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
