Storm Door Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-02-2007, 11:08 AM   #1
Rewards Points: 20
Storm Door Question
Hi. Looking for some help. I just had 2 storm doors installed. When I checked over the work, I noticed that the installer left a small space in the bottom corner of each door (handle side of door-not hinge side). When I asked him about the space he indicated that it was necessary to leave some space because you have to allow for air to vent. He also indicated that w/o the space you'd get condensation. Wondering if there's any truth to this??? Thank!!!
biggerdaddynj is offline   Reply With Quote
Old 09-03-2007, 11:44 PM   #2
Rewards Points: 5,336
That's a load of manure. There's a gap because he didn't set the frame correctly. The brick molding is rarely square. You usually have to shim it, just like any other door set in a rough opening. He didn't shim it.
Ron
Installing a Storm Door matthews1977 Remodeling 4 06-09-2007 12:40 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Moisture in walkout basement after rain storm dannox02 Building & Construction 2 01-24-2006 01:45 PM
