Stone Veneer Preperation??? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 11:09 AM   #1
Stone Veneer preperation???
Help!!! I am going to start redoing my fireplace, but I was hoping to get some tips first. Currently, I have a rock/boulder (80's look) fireplace that goes up to my ceiling. What I would like to do is install the stacked stone veneer over the existing rock, but I am not sure what prep work needs to be done first. I plan to do it in two basic steps..., First put mortar on the existing rock and make it a flat surface until it hardens. Then install the veneer on the new flat mortar wall. I am just worried that it won't stick. Do I need to use some type of concrete bonding agent between layers? And what else am I forgetting. Any help would be appreciated. Thanks.
screwy louie is offline   Reply With Quote
Old 05-07-2009, 06:26 AM   #2
Rewards Points: 5,336
Why don't you post a photo of what you have? Offhand, it sounds like you should remove the boulders first, and then build a frame for the veneer rock.
Ron
Old 05-07-2009, 08:35 AM   #3
Rewards Points: 26
I would think that all that rock/cement/and new stone would be a lot of weight. If it was me I would take out the current rock before installing new.
ponch37300 is offline   Reply With Quote
Old 05-27-2009, 05:02 PM   #4
I'm 3/4 through the same project but I am going over drywall.
As others have said, can you remove the older stone? I don't know a whole lot but I'd at least feel more comfortable not going over existing stone.
Kiwi. is offline   Reply With Quote
Natural stone veneer Jer General DIY Discussions 7 02-03-2009 12:33 PM
Stone Veneer Weight kinglerch Building & Construction 2 08-28-2008 09:39 AM
stone veneer dinodon General DIY Discussions 7 07-01-2008 07:39 PM
