Steps For Putting Texture On New Drywall - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-20-2007, 10:17 AM   #1
Steps for putting texture on new drywall
I have installed new drywall on two walls of my bedroom due to some water damage. I have them taped and ready for texture.
I want to do a new texture look other than the knockdown texture that was there before. I am not sure of the name for this new texture. I have heard it called skip trowel and spanish knife. Not sure which it is or something else. Anyway, I want it to look something like the spanish stucco, but not that heavy.
My question is what steps do I take for new drywall? Do I need to put a thin flat coat of mud on first, or jump right into the finished look I am after?
Do I prime the new drywal before applying the texture or after applying, but before paint?
Thanks for any suggestions.
TNeat is offline   Reply With Quote
Old 12-20-2007, 11:59 AM   #2
Oldguy
Rehabber's Avatar
If all your seams and corners are finished, apply your texture, let dry, prime, (I usually do 2 coats on fresh drywall) and 2 coats of paint.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-20-2007, 03:11 PM   #3
yummy mummy's Avatar
Rewards Points: 1,016
There is a website that has a lot of information about mudding and textures.
www.drywallschool.com
yummy mummy is offline   Reply With Quote
Old 12-22-2007, 12:20 AM   #4
Q: "Do I prime the new drywal before applying the texture or after applying, but before paint?"
A: I always prime my drywall after putting on at least three coats of mud. It is easier to tell if the seams require more attention. Also, it seals the new drywall. If there are flaws, then I apply a thin coat of topper mud as a final coat. Now, it is ready to texture. Since you are going to use a heavier texture, you may not require the last coat of mud. However, I would still prime it.
Handyman50 is offline   Reply With Quote
Old 12-22-2007, 07:39 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Your questions have been somewhat answered already, but I'll clarify....
Originally Posted by TNeat View Post
....My question is what steps do I take for new drywall? Do I need to put a thin flat coat of mud on first, or jump right into the finished look I am after?
Apply your texture directly to the new drywall surface, no other coating is required before that work.
There's been debates on the site about this.
Generally, if you apply a primer coat to your drywall surface BEFORE the Texture is applied: It will take longer to cure, since the moisture content in it can't be absorbed into the drywall. If the area gets considerably wet, the texture is less likely to seperate from the drywall and come off.
Generally, if you apply a primer coat to your drywall surface AFTER the Texture is applied: It will dry and cure faster, since the moisture from the texture can be aborbed into the drywall. If the area gets considerably wet, the texture may seperate and peel-off in larger areas.
Generally such factors are more a concern on ceiling surfaces with plumbing behind it, or a roof over it.
What do we do? We mix flat latex white paint into our texture, then apply it directly over the new drywall surfaces. We figure that if there is enough water damage to an area to seperate the texture from the drywall, it is also going to seperate any taped seams, pop nails/screws, and do other damage that requires scraping off the texture anyways, in order to perform a proper repair...
- Build Well -
Drywall texture matching budking Painting 3 10-29-2007 03:38 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
What to use to spray texture on new drywall? klemmy Remodeling 16 03-28-2007 07:14 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 04:50 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
