Steel Column To Slab Connection - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-08-2013, 01:24 PM   #1
Steel column to slab connection
I will be replacing a load bearing wall with a drop steel beam. The beam will be supported with steel columns. My question is: The current floor is Terrazo, so will I need to cut through the Terrazo to the slab for the column connection with the anchor bolts?
Thank you
floridashaughn is offline   Reply With Quote
Old 10-08-2013, 01:43 PM   #2
joed's Avatar
Rewards Points: 13,694
Thank you
You will need to do more than cut through the terrazzo.
You will need to cut through the slab and install proper footing to support the weight of the load the post will be carrying. Usually a 2'x2'x2' footing is good but you need to have it spec by and engineer.
The Following 3 Users Say Thank You to joed For This Useful Post:
floridashaughn (10-08-2013), joecaption (10-08-2013), Live_Oak (10-08-2013)
Old 10-08-2013, 01:59 PM   #3
Rewards Points: 101
x2 on the engineer. I just did this in my house and a 2 x 2 x2 footer was spec'd by the engineer in NJ
In order to lock in place, I simply dug the footer an extra few inches and then concreted over the base
Thomas
South Jersey - Camden County
tjbingha is offline   Reply With Quote
The Following User Says Thank You to tjbingha For This Useful Post:
Old 10-08-2013, 04:04 PM   #4
Thank you guys!!
Tags
beams , columns , concrete , steel , terrazo
Column location for LVL Beam Perry401 Building & Construction 1 09-10-2013 11:27 PM
Can a 12X20 slab be moved/slid 6 feet? tominblaine Concrete, Stone & Masonry 13 05-30-2013 05:55 AM
Slab for brick column.. What would you do? no drain blues Concrete, Stone & Masonry 27 05-29-2013 10:29 PM
24 x 24 x12 Footer tjbingha Concrete, Stone & Masonry 23 01-28-2013 12:17 PM
which is better to fasten a 3x3 aluminum column to a concrete slab ? filo74 Building & Construction 5 04-29-2010 07:53 PM
