Starting First Course Of Hardiplank - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 08:27 AM   #1
Starting first course of Hardiplank
When starting my first course, should I rip it so that I can avoid notching out 2 pieces of Hardiplank to go above and below my window? In other words I would like to avoid notching as much as possible.
bert1913 is offline   Reply With Quote
Old 06-29-2012, 09:21 AM   #2
Rewards Points: 13,450
Some other ways of doing it would be to rase or lower the first piece so it comes out right.
And adjusting the amount of exposure your going to use can also sometimes work.
Adding a weather board made of vinyl lumber and Z moulding with a strip of vinyl lattis to kick it out above that would add an interesting detail and give you some adjustment to the first piece and help cover up the bottom of the sheathing. I do this all the time when I have to deal with the siding being to close to the grade.
Try and lay it out when cutting the siding so there's no seams directly below or above the window.
HardiPlank Siding - too Heavy? YukonDave Building & Construction 9 02-15-2014 01:52 PM
Air conditioner not starting - Help needed. pipster HVAC 18 09-26-2011 03:39 PM
how to build a single phase induction motor sashman Electrical 3 03-31-2011 07:18 AM
Timecutter 16:42z trouble starting and now stopped starting jackdoldno7 Landscaping & Lawn Care 0 09-10-2010 11:43 AM
Sealant to use with Hardiplank siding JPGO General DIY Discussions 12 07-16-2010 09:08 PM
