Staple-on T&g Ceiling Tiles - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 02:50 PM   #1
staple-on t&g ceiling tiles
I was looking into getting some 12" designed ceiling tiles. My grandfather stated I should use t&g and then I can just glue or staple them into place. My only concern is, does code allow this? Or does drywall have to be behind it? Or are there perhaps fire rated tiles I could use? I can't seem to find any fire rated ones that don't need a suspended grid. Thanks.
Tonglebeak is offline   Reply With Quote
Old 02-05-2010, 05:46 PM   #2
Rewards Points: 5,336
These ceilings need a furring strip frame work to install. These ceilings were popular when your grandfather was in his first house. It allowed homeowners to put up a finished ceiling without needing the finishing skills drywall does.
The problem with these ceilings is that if you need to make repairs for any reason, you need to remove all the tiles to the wall to maintain the T&G format. If styles change, you might not be able to get replacements.
Are there any additional options you're considering?
Ron
Old 02-05-2010, 09:01 PM   #3
Well, it's a 1907 house. Drywall just hurts the character, and by putting in an older, yet modern ceiling (if this makes any sense), I want to bring some of the old character back while still looking great for this time.
Old 02-05-2010, 10:11 PM   #4
The staple up tiles harken to the 1960's
Ron
Old 02-06-2010, 01:42 PM   #5
Ok, so anyways, does anyone have an answer for the original questions? Thanks a bunch.
Old 02-09-2010, 12:29 PM   #6
Bump..
Old 02-09-2010, 12:40 PM   #7
Go to the Hagerstown building dept and ask them.
Ron
Old 02-09-2010, 04:49 PM   #8
That doesn't really help with finding fire-rated tiles :\
Old 02-09-2010, 04:59 PM   #9
why fire rated? you used to be able to get drywall sheets stamped in a pattern that could be used for chair rail. maybe something like that with some home engineering would give you a coffered ceiling look
The older I get the better I was
Old 02-10-2010, 05:07 PM   #10
Drywall contractor
Rewards Points: 1,070
How about the "stamped" metal ceiling material. That should satisfy any firecode issues and still stay within "era" acceptability (and an upgrade to the "staple up"). Costs a bit more though....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Ceiling Tiles - cutting recessed ones? Stargazer General DIY Discussions 5 05-13-2012 10:27 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Ceiling Tiles - Cutting accoustic tiles tstepup2 General DIY Discussions 11 07-21-2009 07:19 PM
Old ceiling tiles - remove? repaint? sertiphyible Remodeling 5 08-24-2008 11:36 AM
Hanging Drywall over ceiling tiles bjorgens Remodeling 4 12-19-2007 01:59 PM
