Staircase - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-26-2014, 09:43 PM   #1
Rewards Points: 4
Staircase
This is my first post here, but by the looks of it I have come to the right place. My wife and I are currently selling our home and have our eyes on another house that currently has a spiral staircase in it. I know this will must likely not be a do-it-yourself job, but I wanted to see if anyone had an idea of what we could to it. The way it currently is positioned is in a very awkward spot. Of course, maybe we can do a condensed spiral staircase, but I would love it if we could do a more modern style (not sure if the wall is big enough). My questions are: does anyone know what might be the cost to add a staircase, ideas on the type of staircase we should put in, and what are we to do with the circular hole at the top if we did do a more modern style? I have included a picture below. The size of the wall is about 16 feet. I truly appreciate any feedback as my wife and I would like to make this our home!
ccguidry is offline   Reply With Quote
Old 11-26-2014, 09:46 PM   #2
Rewards Points: 4
It will not allow me the option to post the photo currently...
Old 11-26-2014, 10:39 PM   #3
joed's Avatar
Rewards Points: 13,352
Costs are too variable depending on location. No one here could give you an accurate estimate. You would need to call local contractors.
Old 11-27-2014, 06:22 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
for a spiral staircase you really need to call a specialist.. most finished staircases are built by carpenters who specialize in stairs. and spiral stairs are usually built by the more experienced ones
woodworkbykirk is offline   Reply With Quote
Old 11-28-2014, 01:08 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 570
We will need more information and pictures before we can help you. I believe you need 5 posts to be be able to post pictures, unless that has been changed.
As for the hole the stairs are in right now, you can frame that hole in. The next question is where will you cut into the floor upstairs for the new stairs. Do you want a radius stairs or a spiral stairs or do you want some other type?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-30-2014, 11:15 PM   #6
Rewards Points: 72
Hello there ccguidry! The cost of installing a new stair would depends on the materials you are going to use. You can ask a quote from a professional stair installation team like Allstairs. My brother has this (picture below) similar spiral stair in his home, thought you might like the idea. Good luck!
emmyshaw is offline   Reply With Quote
Old 12-05-2014, 07:40 AM   #7
Rewards Points: 802
If getting rid of the spiral and going to regular stairs, you may end up spending a lot.
It could start with BY HOUR costs because rough framing will have to be explored - that is, the lumbers that are hidden under the sheetrock - and how they will have to be changed and supported. Spiral needs about the square framing where as stairs need a rectangle, and span and load carrying needs are different and changed.
This can involve reframing the floor/ceiling with the spiral, supporting structure underneath, and the floor/ceiling of the space above. If through the kitchen, you can lose cabinet space. You can lose space in other rooms. This means opening up walls and you may be, then, required to update the utilities behind the sheetrock, minimum electrical (gauge, breaker, gfi) and possibly plumbing.
Just on these points, you should bid low on the house. If you can buy it less than $20,000 minimum than bank appraisal, you may be on the acceptable track for the renovation.
Sorry but all of this is based on a lot of guess with some information.
I'd buy it only if the house needs upgrading and on the market as such.
carpdad is offline   Reply With Quote
Staircase and stair area renovations chukker Remodeling 25 07-12-2014 08:05 AM
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 06:16 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 12:58 PM
Converting an open staircase to a "closed" staircase? tony1853 Building & Construction 7 01-05-2009 01:55 PM
