Stair Spindles-remove Wood, Add Iron - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-18-2008, 01:32 PM   #1
Stair spindles-remove wood, add iron
I am about to take on this project and was wondering if anyone has done this before. I took out a wood spindle and there is a nice drilled deep round hole in the top handrail that the old wood spindle nicely fit into and a round (and not deep) hold where the bottom of the spindle fit into. My question is: I want to replace these with iron spindles and without taking the rail off. My plan is to cut the spindle to the proper length and fit it into the top hole, and then shimmy the iron spindle in to the bottom hole. It will then drop down a bit and the top and the bottom will be not tight. How do I make both top and bottom tight? Do I use epoxy, wood glue etc? Do I then cover BOTH top and bottom with the additional pieces that they sell? I notice that I do not see the top having the additional piece and I think I will need it to cover up where the spindle has "dropped". Am I on the right track? I also know I have to have this level. Thanks for the help.
Jane Olson is offline   Reply With Quote
Old 09-18-2008, 02:16 PM   #2
Registered User
Termite's Avatar
If you're replacing standard wooden ballusters with narrow steel ballusters, be careful. The guardrail needs to prohibit passage of a 4" sphere or it is not code compliant. It might be legal with the wood, but the gap will get bigger putting the steel in there. Just a thought that could someday come back to bite you.
Yes, the ballusters are slipped up into the hole in the upper rail and dropped down into the hole at the floor. You may need to deepen the hole in the rail to accomplish this. Use epoxy to hold them in place. If they don't come with trim pieces that surround the balluster, they are available in most cases. They just can't be an afterthought.
Old 09-18-2008, 03:17 PM   #3
Thank you so much for advising me of the 4" code, I had no idea. Thanks also for confirming the other information. I am ready to go!
Old 11-24-2008, 02:54 PM   #4
Jane -
Did the project work out for you? Did you replace the rail or simply repaint it? Also, did you put the surround trim pieces at the bottom or simply just slide them into the bottom hole?
I want to do this too and am looking for any tips.
Thanks,
Jeff
brandtman is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
How to best attach heavy iron stair railings to home with vinyl siding Alfredo Building & Construction 1 05-18-2008 08:16 AM
