Stair Fix - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 05:35 PM   #16
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Originally Posted by opjar01
Because of the traffic it recieves I was thinking about finishing it off with truck bed liner. I have already considered a skirt board however the gaps are not consistant. If the suggestion is to trim all the risers and treads what saw would i use to do so? And it seems it would be tedious.
That's not my suggestion.
Rhinoliner?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-09-2012, 07:46 PM   #17
Stairguy
Millertyme's Avatar
Rewards Points: 508
a truck bed liner? really?You mean like the rhino stuff that you spray. I would put either 5/4 x 10 or 1x10 syp alongside the wall and the stairs and shim the skirt tight to the stairs. However if the treads and risers are cut to different lengths and are not cut square the skirts will never butt up tight. If your not going to poly the stairs you can just fill in the gaps with caulking or something. A carpet would definitely cover any gaps.
Millertyme is offline   Reply With Quote
Old 01-09-2012, 09:54 PM   #18
Before I continue, Thanks for all the comments/suggestions/help.
Yes to the spray on truck bed liner. It makes perfect sense given the area. Its durable, fluid proof and provides great traction.
Millertyme; what is syp?
opjar01 is offline   Reply With Quote
Old 01-09-2012, 11:27 PM   #19
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
Southern Yellow Pine.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Repair Stair Stringer sunshine54 Flooring 2 11-27-2011 11:06 PM
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 05:54 PM
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 07:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 01:31 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 05:54 AM
