Stair Fix - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 10:35 PM   #1
Stair Fix
How do i fix the gaps on either side of the stairs? I think the original owner intended for carpet to be laid. Gaps are up to 1 inch. Treads and risers are nailed and glued. This is not new construction.
opjar01 is offline   Reply With Quote
Old 01-08-2012, 10:43 PM   #2
Rewards Points: 13,300
If this is new constrution the gaps are there for sheetrock and the skirt boards to fit into. The treads that are there now should be what's called constrution treads. There just rough treads for workers to be able to get up and down on.
If this is an older house there should be no gaps there. What do the treads look like, just plywood or OSB?
Old 01-08-2012, 10:47 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
They are permanent as they're glued.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-08-2012, 11:09 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
Are the stairs supposed to be finished or are they going to do more to them?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-08-2012, 11:18 PM   #5
Disabled wood vet
titanoman's Avatar
The op thinks the original plan called for carpet.
Are they in good shape, the bull-noses not all busted up?
What are you going to finish then with? Are you going to have a skirt
board? The gap should cover, with something, shouldn't they?
Old 01-08-2012, 11:42 PM   #6
I would like to finish the stairs, but need to close off those gaps. Stair material is in good shape just stained from use. Its a high traffic area so im thinking something durable with good traction.
Old 01-08-2012, 11:57 PM   #7
Disabled wood vet
titanoman's Avatar
Like what?? Wood? Rubber? Metal? Paint?
Old 01-09-2012, 06:47 AM   #8
DIY staff
Rewards Points: 7,174
Add wood skirt boards on either side--then a cap molding---
Old 01-09-2012, 07:27 AM   #9
Not trying to add to your post Mike, just trying to add a step to make it easyer to do, I'd finish the drywall , prime and paint it, then add the skirt board.
What may have happened is this was a preassembled stair unit that was just dropped into place.
This is some pictures to show what a skirt board in place should look like.
http://www.stairsupplies.com/eng/com...ls?project=913
Old 01-09-2012, 09:52 AM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
I agree but the space looks a little wide for a 1X12, you may need to install the 1X12 and shim it tight against the stairs then install a run of maybe base cap on top of the skirt to hide the gap. I wish you had had the picture up when you made the original post.
Jim
Old 01-09-2012, 10:51 AM   #11
Disabled wood vet
titanoman's Avatar
How come nobody else is asking how she plans on finishing the stairs? Anything you do, except paint, can cover the gap.
Old 01-09-2012, 03:41 PM   #12
How do i fix the gaps on either side of the stairs? I think the original owner intended for carpet to be laid. (quote)
Your right but by there post carpet is not what there looking for.
Old 01-09-2012, 04:09 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
If anyone didn't go back and look, here is a picture of the stairs the OP posted later.
Jim
Old 01-09-2012, 04:42 PM   #14
Disabled wood vet
titanoman's Avatar
So by finish, they mean leave them as they are.
If it's a 1" gap, I guess a skirt board over 1/4" ply.
Old 01-09-2012, 06:25 PM   #15
Because of the traffic it recieves I was thinking about finishing it off with truck bed liner. I have already considered a skirt board however the gaps are not consistant. If the suggestion is to trim all the risers and treads what saw would i use to do so? And it seems it would be tedious.
Repair Stair Stringer sunshine54 Flooring 2 11-28-2011 12:06 AM
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 06:54 PM
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 08:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 02:31 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 06:54 AM
