Stair Banister On A Weight Bearing Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-09-2008, 06:09 PM   #1
Question
stair banister on a weight bearing wall
Hopefully I can explain this good enough for everyone to understand. The front part of my house is two story and the back then starting in the dining room its one story. The steps is between the Livingroom (two story) and diningroom (one story) there is a doorway coming off both sides leading to the steps. I am closing the doorway to the living room off, and I want to open up the dining room side and install a nice banister, (cut out a part of the wall to do this) BUt that wall is a weight bearing wall, ( I do believe since it is the outside wall on the second story. Can this be done???
angelwill26 is offline   Reply With Quote
Old 03-09-2008, 08:13 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
It sounds like you'll be opening up a wall that has a floor load and a roof load above it, is that correct? How large is the opening going to be? It sounds like it can be done but in any case you would need someone to spec the building materials for you.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
load bearing wall no more grant Building & Construction 5 10-14-2007 09:50 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
