Stainless Steel Sink Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 02:02 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Hello;
We're doing well with our kitchen remodel and will be putting in blocks for the drawer slides today.
We installed a 18 gage stainless steel sink (I thought it was a bit higher end sink, there were many cheaper ones that were 20 or 22 gage). I remember our old sink was rather scratched up over all (but it was almost 50 years old, so I can't really use that as a point of comparison), so I don't know if that is just normal for a stainless steel sink or not. I do have a smaller sink installed in our coffee / prep counter, and I have not noticed any scratches showing up in it, but it isn't as shiny of as surface as this one either.
We have been fairly careful and have not pushed heavy pots around in the sink, they normally go right into the dishwasher (but have had pots sit in there, such as when filling with water). We have a number of obvious scratches that have shown up in the finish / surface of the sink. I just want to know if this is a defect (or that we got a low quality sink, which I didn't really think we did, since it is 18 gage) or if this is normal and it is just more obvious because it is new.
Sink:
The most obvious and largest scratches:
Some additional scratches I've noticed on the other side of the sink:
We seriously have not been hard on it. I would never have imagined stainless steel scratching up so easily that we don't even know how we did it.
Any thoughts on what is going on? If there any way to hide it or blend it in? I tried a softscrub type of cleaner, it didn't seem to do anything, it seems they are scratches right into the surface of the sink.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 04-29-2011, 02:28 PM   #2
fabrk8r
fabrk8r's Avatar
It's normal. Stainless steel isn't as tough as a lot of people imagine. It's basically just mild steel with extra ingredients added. Besides looking pretty it's quality is that the chromium and nickel added to the alloy allow it to resist rust and other forms of corrosion.
There's no getting around scratches, and over time I think it adds character. I build custom stainless steel counter tops and sinks for a living. About all you can do is try to blend the scratch in using a scotch-brite pad and following the direction of the grain. One trick to making stainless steel look like new is to clean the surface with foaming glass cleaner then apply a little olive or mineral oil to the entire surface with a rag, making sure to wipe away the excess.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
jamiedolan (04-29-2011)
Old 05-01-2011, 12:00 AM   #3
DIY'er
jamiedolan's Avatar
Thanks very much for the information and the tips. I'm relived to know that it isn't a defect and that it will blend in over time.
I never even though of using stainless steel for counters in a home, I just looked up some pictures of homes with stainless steel counters and some of them are really impressive. I looked at several different types of counter tops but just ended up going with a nice quality laminate.
Thanks again.
Old 05-01-2011, 08:35 AM   #4
Rewards Points: 5,336
They grates that sit on the sink bottom and protect it from these issues. Buff out the scratches and put one in.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
jamiedolan (05-01-2011)
Sink replacement - 6" to 8" depth; & pvc question snosurfa7 Plumbing 3 08-25-2010 08:32 PM
Stainless Kitchen sink.. What to get? AdRock Kitchen & Bath Remodeling 3 03-03-2010 09:27 AM
Removing dents from stainless steel refrigerator tripower Appliances 4 02-27-2009 06:47 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Gauge of stainless steel sink Not Sure Plumbing 2 08-29-2006 05:56 AM
