Staining Cabinets??? HELP - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 08:07 PM   #1
Question
Hi, I am really want to re-stain our walnut cabinets and need help. I am not sure what is a good stain to use, I want a deep chocolate cabinet. Dose walnut stain well? How far does a gallon of stain go?
BE glad for any feed back
thank you
Netta is offline   Reply With Quote
Old 03-04-2009, 05:10 AM   #2
Remodeling Contractor
Walnut stains very well. A gallon goes a very long way. To get a deep finish you may want to use a dye stain followed by a wiping stain. Buy quality stains at a paint store. Stay away from low quality like minwax and such. I use Mohawk stains.
Old 03-04-2009, 07:21 AM   #3
Try to find an inconspicious place to do some testing first with some samples.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 03-04-2009, 12:58 PM   #4
Post
if you want to get a professional look, make sure that you stain between coats. After sanding, you may want to wipe it with steel wool as well. i dont know the methods/madness behind it but I have done it both ways and and the sanding between makes it look so much better.
Medic507 is offline   Reply With Quote
Old 03-04-2009, 01:05 PM   #5
Maybe a typo? Stain between coats? I think you mean sand between coats. But if using a dye and wiping stain which will give a much deeper look you would not sand between coats of stain. You stain let dry stain let dry and seal. Then sand wipe clean tack cloth and then two or more top coats. You always sand between finishing coats to scuff the surface enough to allow better adhesion of the next coat. (no madness involved here) Sanding or wiping with steel wool is the same thing. One is used for some materials and finishes or surfaces and sanding is used in other cases.
Old 03-06-2009, 04:16 PM   #6
Angry
Preciate that catch. sorry, I did mean stain. Just going by what i have always been told. didnt mean to give any misinformation.
Staining cabinets that have been stained 2 different colors? digexpressions Painting 6 07-26-2008 12:42 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 10:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
