Stack Clean Out Cover - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 03:48 PM   #1
Hello,
I'm hoping to get some help with covering up a 4" stack clean out that was framed and drywalled around. The drywall is flush with the clean out except that the little square plug sticks out approx 3/4". I have looked everywhere locally and searched online and cannot find anything that would cover this 4" opening. The problem seems to be finding something that is dome shaped and has enough clearance to fit over the 3/4" square plug.
Anyone have any suggestions. Please help!
Thanks,
Lee
laterno is offline   Reply With Quote
Old 10-21-2008, 04:53 PM   #2
RippySkippy's Avatar
I can't find it right now...but I'll keep looking. At one time I used a flat clean out plug similar to the one below, except that in the center there's a threaded brass insert that you can use to screw a cover plate to. If I can find it I'll post a picture.
BTW this is a Genova #71854 4" Toe Saver Floor Plug.
EDIT: Here's the item I was looking for...maybe this will help...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
Last edited by RippySkippy; 10-21-2008 at 05:00 PM. Reason: found the referenced item...
RippySkippy is offline   Reply With Quote
Old 10-21-2008, 05:04 PM   #3
Here's some options for clean out covers as well....http://www.siouxchief.com/B_Product_...GroupID=481200
LMASD
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
Patio cover Jackhammer Building & Construction 3 07-10-2007 04:49 PM
Distance to stack rusty_5620 Plumbing 4 02-22-2007 12:39 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
