Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-09-2009, 04:34 PM   #1
Question
Spray foam insulating ceiling under flat roof
Our small, two story, two bedroom row house in Toronto's east end was built in 1921. It is of common design for the time and area, steep-sloped roof at the front, with a large 2nd floor dormer window and flat roof at the back of the house.
We would like to insulate the ceiling under the flat roof, but we're finding very little information about the best approach for this style house.
Should we use spray foam insulation? If so, is open or closed cell, polyurethane, or soya-based foam preferred? Would traditional bat insulation, or rigid insulation be better? Do we need to install a vapour barrier and roof vents?
Any one got any suggestions or recommendations?
Thanks in advance
Jed Lukewater is offline   Reply With Quote
Old 01-12-2009, 08:22 AM   #2
Remodeling Contractor
icynene spray foam is give you the best job and does not need any venting. Searche the web you can order DIY kits. Can spray foam is no good.
Insulating Cathedral Ceiling cholliha Roofing 3 11-25-2008 07:43 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing 2 11-23-2008 11:31 AM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing 11 01-07-2008 09:41 AM
Flat Roof Suggestion gladiator Roofing 3 09-14-2005 04:31 PM
Where flat roof meets shingled roof bstyer Roofing 1 07-07-2005 09:34 PM
