Spiral Staircase Weight - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 09:25 PM   #1
Rewards Points: 191
Spiral staircase weight
Hello and thanks,
Does anyone have a general idea of how much a fabricated spiral staircase might weigh?
I have looked and looked w no real results outside of the premade kits...
I have called around and have been told anywhere from 600-2000 lbs. which is a pretty wide range.
Hoping someone here might have experience w them.
We are talking 8'10" tall and 5' wide along w all the spec's needed to comply with code.
Thanks again
beachfront71 is offline   Reply With Quote
Old 04-30-2012, 06:44 AM   #2
If you bought on, it should have specific requirements with it regarding support needs. If you are just looking, that should be readily available.
Old 04-30-2012, 10:21 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
There are just too many different styles made from many different materials to give a more precise answer so the answer of of 600-2000 pounds would be about right.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-03-2012, 09:17 AM   #4
Rewards Points: 3,130
I put a spiral staircase in when I built my log home (the wife wanted it). It is an all-steel, sort of "industrial looking" thing. It came as a kit and weighs around 700 pounds. It's from a company called Duvinage, whose factory is, fortuitously, not far from here. I just drove over and loaded it up.
If your concern is the need for additional floor bracing, you will most certainly have to do some unless your house is on a slab.
Replacing Spiral Staircase Floridahome Building & Construction 4 01-17-2011 06:26 PM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 05:53 PM
Half-Wall/Sub-Wall around Spiral Staircase Herlihey Carpentry 7 02-03-2010 10:25 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Spiral staircase questions NateHanson Building & Construction 3 01-20-2008 08:49 PM
