Space Between Column/stud - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 07:40 AM   #1
Rewards Points: 492
space between column/stud
project in progress
because of the shape of the column i was unable to put the stud flush against it and get it plumb.
i was thinking i could use a piece of trim/moulding to cover this space. not really sure the best way to proceed.
any suggestions are appreciated greatly
as an aside, I would have never started this project without this website. although it has a taken me a while just to get to this point in the project, i have learned so much from the many posts and generous folks who always are willing to share their knowledge/expertise.
in the pic below, i added another piece to the top plate, to make the space more square. i still have to add the additional top pieces to the second and third front openings.
joetab24 is offline   Reply With Quote
Old 05-08-2010, 11:09 AM   #2
Rewards Points: 492
getting nervous....did i make a major mistake?
Old 05-08-2010, 11:36 AM   #3
kwikfishron's Avatar
Rewards Points: 996
It’s looking beautiful.
That’s what they make trim for.
kwikfishron is online now   Reply With Quote
Old 05-08-2010, 09:24 PM   #4
jlhaslip's Avatar
Rewards Points: 2,862
scribe to the column shape and you should be able to 'plumb' the stud.
add another one to it if you are worried about it losing too much meat.
caulk then add a trim piece if you need to.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-15-2010, 09:37 AM   #5
Rewards Points: 492
for anyone in a similar situation
scribing
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 03:29 PM
Dedicated equipment space for subpanel? WoodworkerDave Electrical 11 09-14-2008 06:32 PM
crawl space confusion shoestring General DIY Discussions 1 07-27-2008 01:06 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
