Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 08-31-2007, 02:34 PM   #1
Steve
STEPHENWANGEL's Avatar
Source needed: 6" Vent Hood for siding
I am installing a range hood in my new kitchen and will be running 6" duct to an exterior wall. Running it through the roof is not a possibility. The roof is new, and I'm not running the risk of a leak by punching through it. The gables have recently been sided, and I need a vent hood that will nest into the shape of the siding. It's Crane Portsmouth shake, with the look of hand-splits. Does anyone have a source for the hood?
Steve Wangel
www.stephenwangel.com
STEPHENWANGEL is offline   Reply With Quote
Old 08-31-2007, 04:19 PM   #2
Double check that 6" will work / many range hoods need an odd ball 7" round or require a 3x10 rectangular duct.
you may need to plan on fabricating exterior vent hood and damper.
Odd balls like this can be very hard to find.
Big Bob is offline   Reply With Quote
Old 08-31-2007, 04:24 PM   #3
Steve
The spec on the blower is for a 6" duct. It's only blowing 350CFM. It's going over a 20" range that on its best day can't generate over 25,000 BTU. For what it's worth, check the web link below... I've done this once or twice before.
The spec is correct, I just need the vent hood!
Steve Wangel
Old 08-31-2007, 05:14 PM   #4
Steve, Just saw your other post and visited your web site ( good quality workmanship) you know your craft. I did not mean to offend by the measure twice on the duct thing.
I recently hunted for a exterior vent hood larger than 4" with no luck.. ran out of time and had a sheet metal shop fabricate what I needed.
I assume your suppliers were no help.
You might want to post this on Contractor Talk: http://www.contractortalk.com/forum
Someone there might have a source.
good luck
Old 08-31-2007, 05:37 PM   #5
Steve
None taken. I don't want to go the custom route, cause I don't want stainless (too industrial). The hood exists, but not for retro-fit. I guess worst case scenario, I'll get the new work hood and modify it.
Steve Wangel
Old 09-01-2007, 06:29 AM   #6
siding supply shop will order one for you. i found this through several manufactures, but neded to order it through my local shop
dcd22 is offline   Reply With Quote
Old 09-01-2007, 07:23 AM   #7
Steve
The siding shops around here only deal w/ Mid America. Does anyone know a manufacturer of the hood that I describe?
Steve Wangel
Old 09-01-2007, 11:15 PM   #8
Did you try Broan?
Ron
Just remembered, HD carries a 6" wall vent. I used one for a kitchen job.
Old 09-01-2007, 11:52 PM   #9
Custom Cabinet Maker
Lowe's also. 6" is normal stuff. any sheet metal or hvac supplier should have stock.
skymaster is offline   Reply With Quote
More On This Topic
Creating delicious meals for the family at home also creates tantalizing aromas in the air. However, you need proper air ventilation to remove odors from grease, smoke and moisture. Whether you're redoing your kitchen or building a new home, several... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. The reason we are setting up another duct blasting, we are going to go ahead and test the duct work again. You... Read More »
On behalf of Expert Village, my name is Gregg Tauriello. I'm from Sweet 16 Studio, and I'm here to talk to you about soundproofing for a recording studio. I'd like to go over a few points about the air conditioning system that I've installed in this... Read More »
How to Do a Rough Duct Test
How to Do a Rough Duct Test by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solution. On behalf of Expert Village, we are going to do a duct test in this house. We are doing a rough duct test on this house. Rough duct meaning literally that the house being built is in the... Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
Vent Hood CFM's wease Appliances 11 04-17-2008 10:18 AM
Kitchen Remodel - Kraftmaid Vent Hood Blower dcd22 Remodeling 3 08-15-2007 04:07 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
range hood vent vinman Roofing 2 07-24-2006 08:37 PM
Island Hood Vent Centering Problems Dana Remodeling 2 07-13-2005 08:37 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
