Soundproofing An Existing Ceiling - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-06-2013, 11:13 PM   #16
I currently own a two story duplex, which the noise travels between the floors quite clearly. The first noise reduction process would be wall to wall carpet on the upper level with a thick pad (considering if both cost and accessibility are possible). The second and most cost efficient method would be to glue sound board on the existing ceiling on the lower level, then attach resilient channel (or less productive "hat channel")perpendicular to the floor joists. Air pockets between the layers play a critical role as does the proper installation of the resilient channel. After you have that done now you can affix 5/8" drywall to the channel, mud it up and paint! The greatness of this process is you can do one room at a time, when time and money are available, not to mention you don't want to live with your whole house in disarray!
CBlock is offline   Reply With Quote
Matching existing wall and ceiling texture Geodude Painting 0 09-27-2010 12:32 PM
Tying in wiring to existing ceiling light samson115 Electrical 3 11-22-2009 12:12 PM
How to wire a 2-prong lamp to a ceiling mount with an existing ground cyantific Electrical 1 08-19-2008 05:22 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-07-2008 11:05 PM
