Sound Insulation - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-18-2009, 05:19 PM   #1
Rewards Points: 730
sound insulation
I am wanting to insulate the floor space between my main floor and basement for sound isolation.
It seems when I google this, I find 1/2" sheets of this or that. I'm not crazy about this for two reasons. 1st, I don't want to drop the ceiling another 1/2" or more and 2nd, the cost seems to get kind of high.
My main goal is just to cut the sound down. I am finishing the basement for a TV/game room and there are bedrooms and a kitchen above this area. I have 2 young girls and I don't want to wake them at night if I watch a movie and I don't want them to disturb the rest of the house if they are downstairs playing. I think you get the idea.
My initial plan was to just install 6" thick fiberglass batting to the floor joists and cover with sheetrock. The little bits I have done, does help, but someone mentioned this isn't a great sound proofing technique. What are some cost effective ideas?
Should I double up the batting in the joist bays, so that it is really dense?
I am having fur out the bottom of the joists with 2x4's to get around things like my a/c line, some plumbing, etc. What about installing some 1-1/2" rigid foam between the 2x4's. So basically, I'd have 6" thick batting in the joists, and rigid foam under.
Thanks for any ideas/suggestions....
Master Brian is offline   Reply With Quote
Old 05-19-2009, 06:30 AM   #2
Basic insulation does not do a lot to block sound, although it does help some. Real sound insulation is expensive. Do a search for sound deadening and you will find a variety of ways to reduce sound travel, none are easy or inexpensive.
Old 05-19-2009, 06:45 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
I understand that "mineral wool" is an excellent sound-deadener, as well as being fireproof. I have no idea what it costs, but it may be something that you can at least check out.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-19-2009, 10:26 AM   #4
Rewards Points: 730
Maybe I'll just have to live with the little bits of help, I gain from batting, which is fairly good. The mineral wool doesn't look to be inexpensive and this isn't that important to where I want to spend $$$ to get the sound down.
I do kind of wonder if blowing cellulose in would be any better. Cost wise, it probably wouldn't be much more than the batting, it would be a bit more work and mess. Hmmm....
The crappy part of this is that my in-laws had a business doing some of this stuff until just a few years ago. When they closed the doors, they probably threw out tons of stuff that would have worked.....
Old 05-19-2009, 01:03 PM   #5
Registered User
Rewards Points: 5,516
I vote for the mineral wool.
http://books.google.com/books?id=VLZ...um=8#PPA137,M1
http://www.gp.com/BUILD/product.aspx?pid=1071
Be safe, G
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
sound insulation 7echo Building & Construction 4 09-24-2008 08:36 AM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 05:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
