Sorta Waterproof Window For OVER A Tub Shower Bathroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-13-2007, 10:47 AM   #1
Rewards Points: 150
Sorta waterproof window for OVER a tub shower bathroom
In the past I have always taken OUT all windows in bathrooms, when putting a shower over a tub and the old fashion window didnt allow THAT. THIS one I am working on has walls tore out yet so open on inside for now!!Am going to put ceramic tile surround above existing tub
It makes it so dark in there. I asked at a lumber yard yesterday and you would think I was speaking greek or something.
Is their a window you can put up high on a bath wall OVER a tub shower?? If it gets slightly splashed or steamed it can survive?? HAS to be vinyl inside and permanent clad outside!!(I dont want wood,less the better here I would think!!) OR should I just put in MORE lighting and leave window OUT??
I think the city code says if I take out a window,,,no window opening in bath I HAVE to put in a stink fan!! Best idea I saw on THAT is a timer for a switch so it runs a couple minutes and shuts off,,,otherwise it runs constantly and wears out VERY fast!!
NO room in this bath to change location of tub and other fixtures either. Tub is on THAT outside wall,,,like it or NOT for me anyway!! Thanks--just don--
justdon is offline   Reply With Quote
Old 09-13-2007, 12:10 PM   #2
Rewards Points: 5,336
I don't know of a vinyl window that has cladding on the exterior. What would be the point, the vinyl is already maintainance free. Your choices are all vinyl or a clad window with wood inside. If you relocate the window high on the wall and seal it, you should have no problem.
Fans should be in every bath, they get rid of humidity as well as odor. You can buy fans that have humidity sensors that go off automatically as well as the timer switches you mentioned. I personally like the remote motor fans where just a vent or two is in the bath. They're very quiet and very effective. They just have a restrictive use. Work well with an attic above.
Ron
Old 09-13-2007, 02:15 PM   #3
I have the same problem. I want to keep the window. When we tore off the ceramic tile the opening for the old long window was there and a small window (still operational) was inside the opening. I would like to put glass block in the original opening, just haven't convinced hubby it's possible. Let me know what you come up with.
skits is offline   Reply With Quote
Old 09-14-2007, 05:18 PM   #4
Rewards Points: 150
Me bad
Ron,
Thanks for the response,,,I was amiss in what I said. What I "MEANT" was I wanted something exterior permanent. I dont want to side the house and have to 'paint' the trim,nor finish the inside. ALL vinyl would be perfect. What brands of windows or what do I ask for when looking for this ALL vinyl window?? Thx,-just don-
Old 09-14-2007, 07:31 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
What you want is: A vinyl window. It can be "New Construction" or "Replacement" style.
Key point: You DON'T want it with any kind of jambs attached to it.
The reason why is that you would want to install your own jambs on the interior side using composite stock (like AZEK or KOMA board, or other).
Use stainless or galvanized nails to install the composite trim around the window's interior side.
Important Point: You want to install the sill at a pitch that allows it to drain towards the tub.
When done installing all the composite trim work, use a mildew resistant caulk with silicone in it.
Side Point: any window can be ordered with "Reduced Visibility" glass = for bathroom privacy. It can be an entire window or one sash on a double hung window.
- Build Well -
Old 09-16-2007, 08:27 PM   #6
zel
Rewards Points: 150
Send a message via AIM to zel
Would glass (or acrylic) block help?
zel is offline   Reply With Quote
shower window farrington135 Remodeling 14 06-10-2012 09:17 PM
Shower window needs waterproof shade 77bronco General DIY Discussions 15 09-23-2010 10:55 AM
window in bathroom, or not? johnny331 Remodeling 18 08-10-2010 01:40 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
Shower window issue help! Ducowti Building & Construction 2 05-26-2005 03:36 AM
