Solutions For Deteriorating Studs? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 10:49 PM   #1
Rewards Points: 83
solutions for deteriorating studs?
Pulled some paneling in our place only to find water damage to the drywall behind. We were going to replace it eventually, so decided to just do it now. When we pulled the drywall, found that 3 studs and the lower 2x4 from a window frame have significant water damage. They're dry now, but are very frail in places...tap them and pieces fall off.
The thought right now is to simply nail in studs right next to them. Are we headed in the right direction? Other thoughts?
dvaupel is offline   Reply With Quote
Old 11-25-2011, 07:34 AM   #2
kwikfishron's Avatar
Rewards Points: 172
Adding sister studs can sometimes be an option but if the wall is load bearing and the studs supporting the header are damaged they should be replaced.
Post a picture of that area showing from floor to ceiling.
kwikfishron is offline   Reply With Quote
Old 11-25-2011, 09:22 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Replace the offending members so the new can be installed exactly where the old is now. This way the measurements will be correct when it comes time to cover it all up with drywall or whatever.
Old 11-25-2011, 09:39 AM   #4
Rewards Points: 83
Pictures wouldn't be available until tonight/tomorrow
The tricky thing with this is that the room was framed off in such a way that the studs don't line up with friendly OC measurements from either wall. One added benefit of tacking in sister studs is we could at least have a stud @ 8 feet.
Old 11-25-2011, 09:40 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well there ya go. If it started off screwy no reason to change any of that just finish it up screwy.
Old 11-25-2011, 10:11 AM   #6
Rewards Points: 150
If you sister each stud on the same side it will have no effect on layout.
To the op. You should fix it right. Dont just pass it off as well it was screwed up in the first place. Post the pictures as previously asked for.
OhioHomeDoctor is offline   Reply With Quote
Old 11-25-2011, 10:24 AM   #7
Home Remodeler
Rewards Points: 164
Dry rot is a fungus and needs to be treated or removed. It is caused by moisture so you need to make sure the leak is repaired. Some leaks only happen when the wind is blowing a certain way and is raining. Do a search on dry rot, lot of information out there. If it is not done correctly it may spread to the new studs.
mikey48 is offline   Reply With Quote
Old 11-25-2011, 11:16 AM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
Mikey is right, no matter what fix you come up with you have to find and fix the source of the leak.
That, I think, should be a priority.
Andy.
AndyGump is offline   Reply With Quote
Old 11-25-2011, 02:00 PM   #9
Rewards Points: 83
Moisture is no longer a concern...There's now an attached garage on that side of the house. The moisture resulted from a window that has since been removed because of the garage.
Old 11-25-2011, 11:58 PM   #10
Rewards Points: 83
PIcture of the problem area
Here's some pictures from the area in question:
Old 11-26-2011, 12:08 AM   #11
AndyGump's Avatar
Rewards Points: 662
Don't over-think this, you no longer have the water infiltration problem great.
Sister on to or take out the existing studs (may be the better thing), Drill holes in new studs for electrical, Cut out the insulation nicely around the electrical boxes, de-laminate the insulation and surround the conduit with the insulation.
Vapor barrier the insulation and re-install drywall.
Andy.
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
