Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-28-2013, 01:38 PM   #1
Solid oak mantel shelf ideas
I am building a solid oak (8/4 x 10 stock) with a finished size of 1.75 x 9.75 x 50" and would like some mounting ideas. It will incorporate 2 corbels mounted to sheetrock over 2 x 4 stud framing. I want to keep it clean which means no molding hiding hardware. Any ideas will be helpfull.
tgrosskopf is offline   Reply With Quote
Old 01-28-2013, 01:55 PM   #2
Long hanger bolts used the same way as rail bolts are used when building hand rails.
Counter bore holes in the under side so you can get a nut on the bolt and plug the hole with 1" plugs.
Old 02-08-2013, 10:56 AM   #3
Is it for a fireplace? Have you considered wrought iron brackets?
Our daughter has a brick FP in her family room with wrought iron
brackets and its a nice look.
We also have a shelf in our foyer with wrought iron brackets
and I like the look.
oops...I just re-read your post and see that you're using corbels.
Two Knots is offline   Reply With Quote
Old 02-13-2013, 04:27 PM   #4
If u r opening Sheetrock u can either use double threaded bolts and insert into oak and put 2x6 on fkat between studs with a whole for bolt with nut snd washers n inside but that is tight. Or notch your studs 1 1/2 thick by couple inches higher than mantle then screw 2x material to mantle leaving some exposed above and below so u can. Screw into studs.
kaschmid3 is offline   Reply With Quote
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
Quick weekend project: Plant Shelf in Foyer hyunelan2 Project Showcase 1 01-04-2012 08:00 AM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 07:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 09:07 AM
Building a Cabin on Solid Rock thatstaken2 Building & Construction 1 08-11-2008 09:28 PM
