Sole Plate On Basement Floor: Remove Tiles? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-24-2013, 02:02 PM   #1
Rewards Points: 53
Sole Plate on Basement Floor: Remove Tiles?
I have a lovely 1950s basement with those awesome 9x9 asbestos tiles. If I want to put in a wall, can my sole plate live atop those or does it need to be secured directly onto the underlying concrete?
corsulian is offline   Reply With Quote
Old 08-24-2013, 03:03 PM   #2
Rewards Points: 13,250
Go right over them.
oh'mike (08-24-2013)
Old 08-24-2013, 07:14 PM   #3
DIY staff
Rewards Points: 7,174
Yep---no need to remove the tiles----
Old 08-25-2013, 10:57 AM   #4
Rewards Points: 53
To thicken the plot - any particular need to remove them in order to eventually put something nicer on top, floor-wise? I've seen mixed advice on laying a subfloor on top of these things.
My first thought was a layer of DRIcore - although, as with most things, it seems 50% of people praise it as the finest invention ever 50% say it'll cause nothing but extreme feelings of regret as it devours our hopes and dreams.
Old 08-25-2013, 07:07 PM   #5
DIY staff
Peal them off and set some ceramic tile---no wood products to get musty or moldy.
Old 08-25-2013, 10:46 PM   #6
Registered User
Rewards Points: 5,204
You need to insulate/isolate (decouple) the slab from the carpet/laminate; Basement floor - prep / tile underlay?
Gary
Tags
basement , sole plate
Vinyl Plank flooring over VAT tiles in basement? jdtox Flooring 5 10-16-2012 08:21 AM
Clay tiles under concrete basement shorteared Flooring 6 11-02-2011 10:22 AM
Can I drill through Sole plate cleon Electrical 3 10-08-2011 09:31 AM
Sole Plate Over Perimeter Drain DIY_ing_Guy Building & Construction 6 02-15-2011 11:37 AM
Replace basement sill plate Bcoleman6 Building & Construction 7 01-15-2011 11:01 PM
