#1 |
Soffits for Heating ducts
Does anyone have a suggestion for building a soffit for a heating main trunk?? The problem is I really can't do the traditional 2x2 framing underneath the duct cause it will put me about 1.5 inches below code height of 6'8". The run I need to do is only about 4 feet long and the section of the trunk that I need to do is 2 feet wide. Can I just run the wood support right next to the trunk and not have any support from underneath for the drywall?? I am not sure if that will sag or not. Any other suggestions would be greatly appreciated. I am open for anything except moving the main trunk. Way to labor intensive!!
#2 | |
Lic. Builder/GC/Remodeler
Soffits for Heating ductsQuote:
Build a 2x3 wall on each side of the duct. Build it so that it is even with the bottom of the duct work (in terms of their height off of the floor) Now, purchase what's called 'spring board' (3/4" thick rough boards that are about 16"+ wide) OR: Better alternative: Get some 3/4" Plywood and cut it into 16" wide lengths (as opposed to normal 2 1/2" strapping). Attach these to the frame work that you built on each side of the duct work. The advantage of using a wider board than normal strapping, is that over the 24" of area, there will be very little, if any, sagging at all. So, you will only be taking 3/4" off of your head room + whatever the thickness of the sheetrock is. Even Better Alternative: If you use the 3/4" plywood over the entire bottom of the duct work, then you could get away with 1/4" sheetrock attached - onto that = Only about 1" loss in head room (Tho, I don't know if that amount will get you the head room that you want)
- Build Well - Last edited by AtlanticWBConst.; 01-27-2007 at 10:36 PM. |
#3 |
The Menards by me has some High Strength sheetrock that is supposedly able to span 24" on center and not bend. Anyone use it??
#4 |
I believe normally code say the minimum height in most of the area only, it should allow height lower than minimum small percentage of spaces... this is not avoidable in most basements, there are low spots here or there... I doublt for such relative small area, lower than a few inches will really be an issue, as I remember I read my code before only saying things like "mainly", "mostly", ..etc. not "absolutely"...
#5 | |
Codes vary by region and also by local town or city requirements....
- Build Well - |
#6 |
I posted a reply about this on your other post inquiring about the High strength sheetrock....
- Build Well - |
| Display Modes | |
| How far should insulation be from heating ducts... | AllGoNoShow | Remodeling | 4 | 11-09-2006 06:47 PM |
| Using PVC ducts instead of standard ducts | robertmazzo | HVAC | 3 | 10-05-2006 05:26 PM |
| Going from 4" to 6" ducts | Lynn | HVAC | 3 | 07-15-2005 05:12 PM |
| Installing Central Air using existing heat ducts | lvlacic | HVAC | 2 | 06-25-2005 01:47 AM |
