Soffit Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 12:23 PM   #1
Soffit question
I have a quick question about what someone else would do in my situation.
I am building a soffit around my I-beam and 2 other ducts but my issue is that they hit the window if I completely box them in. Luckily, the last one is short than the others. But I am not sure if I should go all the way to the duct or just move in enough to clear the window.
So basically, 3-4 inches or 16 inches.
That shows the ducting and the window, hopefully that makes sense. If not I can take pictures and try to describe better. I just don't know if I go in all the way, if it will look stupid. Just wondering if you guys have any suggestions, or what you would do.
Thanks,
Nick
ndmeier is offline   Reply With Quote
Old 03-03-2012, 02:52 PM   #2
Rewards Points: 2,210
Just angle it after you get past the ducts? To me the smaler angle will look better than the steeper angle. Leave enough room for window casing and an extra inch or 2
mae-ling is offline   Reply With Quote
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 10:01 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 06:01 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 08:30 PM
