Soffit/Bulkhead First Or Walls? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 10:03 PM   #1
Rewards Points: 77
Soffit/Bulkhead first or walls?
Basically, before I start framing my basement, what usally comes first? Is it just preference?
Thanks to all!
mlijoi is offline   Reply With Quote
Old 11-04-2012, 10:42 PM   #2
walls first so you have something to attach the soffit to.
The Following 2 Users Say Thank You to DannyT For This Useful Post:
mae-ling (11-05-2012), woodworkbykirk (11-05-2012)
Old 11-05-2012, 12:02 AM   #3
Rewards Points: 2,202
sorry was thinking drywall - post deleted
mae-ling is offline   Reply With Quote
Old 11-05-2012, 09:07 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
frame the walls first and build the soffit/bulkhead to the wall framing and then fireblock in the wall where the bulkhead lands on the wall.
hand drive is offline   Reply With Quote
Old 11-05-2012, 10:26 AM   #5
Rewards Points: 77
That's what I was thinking. Thanks a lot and I'll be looking for some more advice as I commence the work.
Great to know there is people like you folks!
Old 11-05-2012, 04:12 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
for proper firecoad. build and hang the wall. then build the bulkheads.. by doing so your stopping any chance of smoke passing through the wall.. this is the required method for commercial construction a
woodworkbykirk is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
