Soffit Building Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 08:04 PM   #1
Rewards Points: 113
Question
I have a question regarding building a large soffit to enclose an I-Beam, ductwork, gas line, water line, etc in a basement finishing project.
The soffit size is roughly 15' L x 7' W x 1.5' H. The floor joists above are engineered or I-Beam style.
My current plans are to build a frame with 2x4's then finish with drywall.
My questions are:
  • How can I safely attach to the floor joists?
  • Is using 2x4's a good plan?
  • Any other advice on how to build the soffit or tie into the walls on either side?
Here are a few photos showing the space to be enclosed:
Soffit Building Question-dsc00897_resize.jpg   Soffit Building Question-dsc00901_resize.jpg
mklein49 is offline   Reply With Quote
Old 01-04-2013, 11:46 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Hmmm....I would have thought this would have been jumped on by now. Everyone must be asleep.
1. Nails or screws if using lumber. I prefer screws when using steel.
2. Not my choice. I much prefer steel. Lighter and faster IMPHO.
3. Build perimeter walls first then build your sofits to meet them. Typically build a ladder type sofit wall on each side the connect the two with your material of choice. I use steel wall track, steel studs and then hat track to connect. Some like to use 1\2" plywood and actually build a box around them. Never tried that way.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
woodworkbykirk (01-04-2013)
Old 01-04-2013, 09:26 PM   #3
Registered User
Rewards Points: 5,244
Is that a union at the end of your gas line, may want to check with your local AHJ on enclosing that, need a permit anyway for insurance liability and electrical anyway. http://publicecodes.cyberregs.com/ic..._24_sec022.htm
Gary
Soffit question ndmeier Remodeling 1 03-03-2012 02:52 PM
vinyl Siding / Soffit Question J S Machine Building & Construction 42 04-18-2011 11:11 PM
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 10:01 PM
Composite deck building question Big Marino Carpentry 6 12-31-2008 11:14 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 08:30 PM
