Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-18-2012, 01:44 PM   #1
Soffit between two walls in basement
Is there a particular way that a soffit needs to be "isolated" from wall framing, as far as code goes?
I have a lam beam and HVAC trunk line which span the width of the middle of my basement. there will be a wall at either end of the soffit. I feel like i read somewhere that the framing needs to not be connected, or something relating to firestop purposes.
TIA!
joem01 is offline   Reply With Quote
Old 01-18-2012, 02:17 PM   #2
I am in Canada and have not had to do that. Best to check with some one local. Building inspector or carpenter.
mae-ling is offline   Reply With Quote
Old 01-18-2012, 08:06 PM   #3
Firestop is for between floors.
Run the soffit between the two walls. I like to use steel studs for soffits, because they are straight.
Good luck,
Bluehawks is offline   Reply With Quote
Old 01-19-2012, 09:20 AM   #4
Good luck,
gotcha. so I'd want to close off the top of the soffit from the joists it's secured to, above. the walls should have no bearing and I can just run the soffit right up to the walls.
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
How to Prep. Basement Walls for Painting vcheez Building & Construction 37 08-12-2011 10:32 AM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 04:42 PM
