Smoothing Out Old Surface For New Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 01:01 AM   #1
Smoothing out old surface for new tile
Just removed old tile. How do I smooth out old bumpy surface for new tile? What methods do I use?
jclee is offline   Reply With Quote
Old 07-03-2013, 06:29 AM   #2
DIY staff
Rewards Points: 7,174
A few more details please---
The 'bumpy surface'---are you talking about a concrete floor, drywall, plywood or something else??
Sometimes you will grind the surface--other times ,removing the bumpy surface and replacing with fresh drywall or subfloor is best--
other times burying the old surface under self leveling compound is called for.
Old 07-03-2013, 06:45 AM   #3
Amateuralex's Avatar
Rewards Points: 270
If it's just the old thinset, use a floor scraper or hammer and chisel to knock out all of the loose material, then vaccuum it all up, then you should be all set to tile over it.
Amateuralex is offline   Reply With Quote
How to remove single 18" ceramic floor tile hkeiner Tiling, ceramics, marble 8 02-28-2013 09:56 AM
"Temporary" tile job? M3 Pete Tiling, ceramics, marble 5 02-27-2012 03:01 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
replacing wall tile on uneven surface johnpaul8379 Kitchen & Bath Remodeling 2 02-22-2011 03:26 PM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 11:50 AM
